couple serrage cache culbuteur
2 participants
- doozNouveau
Lun 5 Déc 2022 - 5:41
bonjour après recherche je retrouve pas le couple de serrage du cache culbuteur pour mon zafira b (a05) 1.6 (m75) essence 85 kw 115 ch 2009 écho tec je voudrais changer le joint que j ai commander il suinte a l'huile merci d'avance.
- dglobo926 places
Re: couple serrage cache culbuteur
Lun 5 Déc 2022 - 23:11
- doozNouveau
Mar 6 Déc 2022 - 5:42
merci le moteur est un z16xer
- doozNouveau
Mar 6 Déc 2022 - 5:45
du coup avec la ref moteur ca me dis 8Nm serrage en escargot juste ?
- dglobo926 places
Mer 7 Déc 2022 - 21:15
oui ci dessous les couples pour ton moteur. C'est le dernier dans la liste
Nm
Cover bolt to camshaft adjuster
30
Axle shaft in wheel hub
Tighten to 150 Nm, slacken by 45°, then tighten to 250 Nm
Starter to cylinder block
25
Exhaust manifold to cylinder head
221)
Battery bracket to battery support
7
Battery support on body
15
Oil filter housing cover to oil filter housing
25
Torsional vibration damper to crankshaft
95 + 30° + 15°2)
Throttle body to intake manifold
8
Intake pipe pressure sensor to intake manifold
8
Dynamic oil level control to oil pan
10
Intake manifold to cylinder head
20
End silencer to exhaust pipe
50
Accelerator pedal to bulkhead
12
Guide joint
50
Alternator on pump module and cylinder block
35
Transmission to cylinder block
60
Left engine damping block support to transmission
35
Right engine damping block support to cylinder block
502)
Rear engine damping block bracket to transmission
80
Engine damping block bracket to engine damping block support (left)
55
Engine damping block bracket to engine damping block support (right)
55
Heat shield to exhaust manifold
8
Crankshaft pulse pick-up to pulse pick-up bracket
4.5
Refrigerant line to receiver-dryer
20
Refrigerant line to refrigerant line
20
Ribbed V-belt tensioner on cylinder block
50
Knock sensor to cylinder head
20
Fuel distributor pipe to cylinder head
8
Coolant flange on cylinder head
8
Coolant pump on pump module
8
Coolant pipe to pump module
8
Coolant pipe to thermostat housing
8
Crankshaft bearing cap to cylinder block
50 + 45° + 15°2)
Mixture regulation oxygen sensor to exhaust manifold
40
Catalytic converter control oxygen sensor on exhaust front end
40
Rear engine damping block to bracket
55
Rear engine damping block to front axle body
55
Left engine damping block to body (side member)
20
Right engine damping block to body (side member)
35
Front engine damping block to transmission
80
Front engine damping block to front axle body
55
Engine control unit to intake manifold
8
Engine transport shackle to cylinder head
25
Camshaft bearing caps to cylinder head
8
Camshaft sensor to cylinder head
6
Oil drain plug to oil pan
14
Oil pressure switch on cylinder block
20
Oil pump cover on pump module
8
Oil baffle plate on oil pan
10
Oil pan to transmission housing
40
Oil pan on cylinder head and pump module
103)
Con-rod bearing cap to con-rod
35 + 45° + 15°2)
Pump module on cylinder block
20
Wheel to wheel hub
110
Coolant pump strap disc on coolant pump
20
Swing arm to spring strut
551)
Hose clamps for air intake hose
3.5
Flywheel to crankshaft
35 + 30° + 15°2)
Exhaust manifold support to exhaust manifold
20
Tie rod end
30 Nm + 90° + 15°2)
Exhaust manifold support to cylinder block
20
Intake manifold support to intake manifold
8
Intake manifold support to cylinder block
8
Thermostat housing on coolant flange
8
Excess pressure valve to pump module
10
Lower radiator bracket to front axle body
15
Climate control system compressor on pump module and cylinder block
22
Condenser to radiator
5
Closure bolt for oil pressure measurement on cylinder head
15
Closure bolt, oil pressure regulating valve to pump module
21
Camshaft adjuster to camshaft
65 + 120° + 15°2)
Front axle body to body (all bolts)
90 + 45° + 15°2)
Front exhaust pipe to exhaust manifold
20
Rear toothed belt cover on cylinder head
6
Front toothed belt cover (upper) to rear toothed belt cover
4
Front toothed belt cover (lower) to pump module
6
Toothed belt tensioner on cylinder head
20
Toothed belt deflection pulley on cylinder head
25
Spark plugs to cylinder head
25
Ignition module to cylinder head
8
Intermediate spindle to steering intermediate spindle
224)
Cylinder head to cylinder block
25 + 90° + 90° + 90° + 45°2)
Cylinder head cover to cylinder head
8
Nm
30
25
221)
7
15
25
95 + 30° + 15°2)
8
8
10
20
50
12
Guide joint
50
35
60
35
502)
80
55
55
8
4.5
20
20
50
20
8
8
8
8
8
50 + 45° + 15°2)
40
40
55
55
20
35
80
55
8
25
8
6
14
20
8
10
40
103)
35 + 45° + 15°2)
20
Wheel to wheel hub
110
20
551)
3.5
35 + 30° + 15°2)
20
Tie rod end
30 Nm + 90° + 15°2)
20
8
8
8
10
15
22
5
15
21
65 + 120° + 15°2)
90 + 45° + 15°2)
20
6
4
6
20
25
25
8
224)
8
- doozNouveau
Jeu 8 Déc 2022 - 6:07
